Hoping to go to the track Friday
TurboTer
Zap! Commander
I'm hoping to take the '85 GN to the track this Friday for the first time. Any idea what times I should be capable of running? My only mods are listed in my sig.
On a somewhat related note, what should my next mods be? I probably will convert to a 1987 ECM next.
you should run atleast a low low 13 if everything is working right.
Wow, that fast? Remember, I only have the stock injectors, a stock chip, and just a 237 fuel pressure regulator. I was hoping for 14 flat times, but I really hope you are right. :)
i went 13.6 with an unbolted DP, adj fp reg, home depot cold air kit, and a jay carter high boost low timing chip (and this was only 17psi boost.. )
everything else was stock, you have 3" dp and the 2.5 made a HUGE DIFF than the stock one.. of course the car has never run right sense but if you have drag radials and pull some good 60 fts (1.8x atleast) you should run well.
