Horn assembly Allen bolt
Yamil87GN
I need the bolts for the horn ring that attaches to the steering wheel.
I would like to know the size to look for the right one.
Amazon has the screws although in Stainless.
Not sure of the drive size on the above mentioned screws. The OEM are 4mm Hex and the head is 8.8mm Dia. x 4mm height.
Thanks! I’ll get them.
What about the center console? Do you know what type of bolts it has? I had mine not installed when I got the car I can see the bracket under the shifter and under the back compartment it takes two bolts but don’t know what kind, I don’t want to do a random size..
