dmcampbell7
- Oct 28, 2015
Hoping someone can explain how the GN/T Type horn buttons work. I have a plain Jane Regal that I’m putting a t type steering wheel on and have pieced together the parts. The steel contact part with the wire that connects to the horn feed was severely rusted so I got all the rust off and painted it to keep it from rusting again, knowing I’d have to remove the paint from a surface or two for grounding the plate. Problem is, I’m not sure what surface. It’s hard to tell how these actually work and if I’m missing a spring or something. I do understand that the wire and tube slides in and locks like on my old wheel. Can someone take a minute to explain how these work and if I’m missing a component? Also, if you could look at the pics and pic the surface or surfaces I need to remove paint from, I numbered them. Thanks in advance!
