87GN_ponykillr
Buick addict
- Nov 25, 2003
I posted this in the tech area also... I figured maybe some hot air guys might catch it in this section. Thanks guys!
Ok, What I have to sum it up... Yesterday we had the 84' on her first "road trip" (left town) it was very hot and she got up to 70 75 mph on 95 when the SES light came on and started the stumbles and power loss. We get the car to the side of the road and pop the hood and hot as hell about sums it up. No boil over just ton of heat upper rad hose was to hot to even get near. We let her cool down a bit then started back up no problem but not running that good. It went about half way back home easy driving then pulled over for another cool off stop. The car did make it back to the house SES light on the whole way. We checked the coolant and had some crud in it (no milkshake) the oil was fine, clean as can be. I'm sure nothing blew in the motor gaskets seem good etc. So today I came back to look into it a bit more after work and started it to back up a bit no problem starting but she was not running right. I put the code scanner on and found nothing the scan tool said all is fine, well far from the truth. So I disconected the battery then reconect and that did not fix the problem. I then try to start, and notta this time
 the scan tool said all is fine, well far from the truth. So I disconected the battery then reconect and that did not fix the problem. I then try to start, and notta this time  I have fuel but no spark, I did get it to run for a few seconds put with the gas down. So time for the paperclip trick.... That came up with a code 51 ; ECU so...... Anyone ever pull a 51???? I'm not even sure what that code can mean? After that I pulled the rear driver side plug and that thing is BLACK fuel feed bad... A very small spot of oil but not covered just smells like a fuel truck. I checked all the basics wires, connections for loose ends or burns but everything is all and well? Any ideas guys? Thanks in advance. -Adam
