hot air parts for cheap!
BW Jones
having a 'full of hotair' sale .... need to get this stuff out of my way!
all parts for 84/85 (hotair) turbo buicks.
THROTTLE BODY WITH IAC HOUSING, THROTTLE BRACKET & RETURN SPRING
2 FUEL RAILS
2 FUEL INJECTOR HARNESSES
EXHAUST CROSSOVER PIPE
2 MAIN ACCESSORY BRACKETS
THERMOSTAT HOUSING (WATERNECK)
2 WATER PUMP PULLEYS
EGR PIPE WITH HOUSING THAT THE EGR VALVE BOLTS TO
A SET OF FUEL LINES
TURBO OIL DRAIN TUBE
CRANK PULLEY
PWR STEERING PUMP
2 ALTERNATORS
TURBO OIL FEED LINE
A/C COMPRESSOR
all parts in very good to excellent shape
$125 buys everything
bw jones
BW,
Any more TV cables for them?
p.s. did you ever get the CPT 'verter in?
Brian
parts
brian,
seems like a saw a tv cable while going through stuff. i'll double check and let you know.
i got the cpt convertor in but haven't had a chance to get to the track since ....... it's either been raining or 100 degrees :cool:
bw jones
Do both of the alternators work? Are they AC Delco units or remans? Put me inline first. Also what would shipping to a business at 80917 cost?
hotair parts
my85grandnation,
i don't know if they are AC Delco units or remans, but both work just fine and are in great shape. i'll have a shipping quote for you tomorrow.
bw jones
Are they black painted units like they came with from the factory, or are they just metal color?
parts
close-up pics of the alternators below ........ as you can see, they say 'delco remy'.
$40 for shipping (isn't cheap as the box contains MANY parts and several of them are heavy).
bw jones
Ttt
never heard from MY85GRANDNATION
parts are still available and are a great bargain for anyone that can used some very nice hot-air items.
TTT
bw jones
Sorry got busy. Would you sell me just one of everything that you have 2 of, and leave out the a/c compressor and the crossover? Please let me know. Thanks Dusty
dusty,
to clarify ....... you are wanting to purchase the following:
the throttle body & it's accy pieces
a fuel rail
an injector harness
an accessory bracket
water neck (t-stat housing)
a water pump pully
the EGR pipe
fuel lines
oil drain tube
crank pulley
PS pump
an alternator
turbo oil feed line
please let me know if this is correct :confused: .
if so ........ this would be 13 of the 20 items i had listed. how about $85 plus actual shipping? that's about $6.50 per item :eek:.
if that's good with you, i'll box it up and get a shipping quote for you.
let me know.
thanks ........ bw jones
Yes that is correct. The alternator on the right in the pic is the one I would like I think as the other one appears to have some oxidation and rust on the case and bolts. Please find out what shipping is to where I work at 80917 as it is cheaper than a residence, and I could get you out either paypal, personal check, or money order later this week. Thanks Dusty
Just checking to see if you figured out what shipping was going to be yet. If you know it please let me know the total I need to send you. If you accept paypal please let me know your paypal address and I will get a payment sent out. Thanks Dusty
Payment sent, but I goofed and forgot to check my work address in the shipping box so it has my home address listed. I will PM you my work address so you can ship it there for the shipping discount. Thanks Dusty
