hot air questions
the wrath
i have a buddy that is having a bunch of issues with his hot air car his plugs foul out alot and he is getting a code 34,43 and his plugs foul out alot and his car has the original coil and module on it too if you have any ideas of what this could be fouling out his plugs let me know
transplant an intercooled motor ;) .;)
This is clearly not the answer if a friend is asking the question. Converting an 85 to an intercooler is dollar foolish and labor intensive unless you know how fast you want to go and are you a dragger?. A Razor Alky kit can get a hot air moving as well. But that is not your problem. It is your MAF.
At this point on a hot air you need to convert to the 87 ECM and 87 MAF. The 85 and 87 MAF are not made anymore and the reman MAFs are a 1 in 10 chance of working. Buy a good used 87 MAF. If you cant find one after you convert to the 87 ECM and chip go with a LS1 and translator. The 87 MAT sensor will be an issue depending on your new ECM chip. I would also dump the 85 coil and pack and convert to the 87. You will need the conversion kits from Caspers. Good luck. Brad
By the way- I am local and can show you first hand how to fix it. Give me a call- 847-836-5800-work. Brad
Ya Gary what the hell is wrong with you, Derrick is your friend and this is how you treat him? Oh wait, you were really try to help him in the long run. My bad!!!
Man this is too much for me.:biggrin:
Prasad
OK I can see this is starting to get ugly.
Brad please dont get upset at my "convert to intercooled" comment, I only posted that because the Wrath and I are real good friends and thats usually a good way for him to get a laugh since all he does is check TB.com when hes supposed to be working....see I did it again. As far as Hot Air cars go, I have no problem with them since they look the same as 86-87s anyway. So please accept my apology.
Brer- I did not get offended at all concerning the quote and no apology was necessary. Never the less all I want to do is help people just as they have helped me over the years. Thanks- Brad
