m2mtrsports
- Aug 3, 2015
Recently got this, had a bunch of maintenance done.
Timing cover gaskets, coolant, hoses, oil/filter, trans fluid, valve cover gaskets, coolant temp sensor, some vac leaks fixed, intake tube crack patched. Just trying to get it to run right before anything else.
Same engine as the Regal, just different trans.
Have a code 14, new coolant temp sensor. have 5v between the 2 connectors at the sensor plug with engine off key on.
From what I have seen this should make it run lean. It runs like it is on 5 cylinders, hesitates. Hard to start, popped once.
Have not done plugs/wires yet.
What else can cause this?
Will look into it more this weekend.
Thanks,
Thanks,
