The pink wire is from the hot from the ignition. As I look at the wiring diagram, the purple wire goes thru the harness, and ends up at the "bat" side of the distributor. Since I am not stock, can the second wire in this two wire connector"purple" wire, go directly to the "bat" side of the distributor. Also, just picked up the top end from a '78 3.8 Turbo. Have the red carb hat, hose, filter can, and the black charcoal(?) caniser. Also have complete wiring harness. All available.
Dan
Dan
