While waiting for my transmission from PMAC i was in the Lab(garage)checking all my ground wires and other things when i decided to re-hook my intank fuel pump hot wire kit back up, it did not work, i replace the fuse no luck the car would run with my bosch 286, but when i pull my fuse for that pump the car would die. I then plug the stock wires for the pump back up. it ran fine but when the hot wire kit is plugged up it would not start....this kit is a easy hook up what gives
the wire is hot all the way back to the relay(before it enter the relay)I`m lost on this one
