Hot wire kit.
kilhef
Installed new fuel pump and now ready to inslall hot wire kit. What is the easiest and best way to run the harness.
If you see the engine compartment picture; follow the black cable with the white tag and it's tie-wrap towards and underneath the PowerMaster down by the brake proportioning valve. The next picture shows the cable tie-wrap inside the channel exiting out towards the gas tank. You DO NOT need to cut the cable; you might need a coat hanger wire to pull the cable.
Thanks you very much!!
