How do I ID the valve body?
turbo1962
I have three, 4203 D3 326 AS
4203 D11 296 AS
4203 D3 216 AS
The one in the car is the 326 the governor is different from what the GN looks like, My shift points are to high and moving around. Is this the wrong governor ? Have no history on the trans. Where do i start??? Thanks for any HELP!
4203 D11 296 AS
4203 D3 216 AS
Are their any ink stamped numbers or marks on it? if so what do they say and the color? Is their a metal tag on the tail shaft of the tranny with numbers...
I will have to check on the Tags their was some numbers in ink i could only make out one it was BRE in yellow the other were white the trans that was in car was in white does the other numbers tell me any thing. i took and welded a bead on the governor now it shifts at 5300 1st to 2nd 5000 2nd to 3rd .. IT was shifting at 5800 from 1st to 2nd
