crashedout1
- Feb 23, 2011
Can anyone tell me how I can verify this block car has 96k on the clock but these cylinders are standard bore and don't have a ridge maybe the engine was replaced any info is appreciated
SignUp Now!OK so the number is 25514290 which comes out to be a 1979 turbo block what's it doing in a 84 must be a low mile block
so the information on gnttype.org is wrong?
So its a true turbo block also?
OK I got another block which has all the hot air stuff 25514140 what's this one?
Im pretty sure my car has a 109 block and its an 85, does that mean its not original? Its a hot air.This block is from a 1985 non-turbo Buick. The correct block for a turbo car in 85 is 2552329. There are no difference between the two blocks whatsoever. My old GN had the block and the engine worked perfectly. You see the 140 blocks a lot simply because the made more of them.
I really appreciate the help I'm trying to get this car back togetherThat's not even the correct number of digits.![]()
