Nov 19, 2018 #1 8 87we410877 Well-Known Member Joined Apr 5, 2005 Messages 2,634 As the title says. I believe they are push pins. Can someone verify or possibly post a pic? Thanks! Attachments 8D68B61D-EEB5-4530-9815-BFECDAFC202C.jpeg 1.9 MB · Views: 173
Nov 19, 2018 #2 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,609 if they are new they should have come with the push pins sides use push pins and then get zip tied to bumper strut bottom flap bolts to underside of rad support using short 10mm head coarse bolts with an integral washer , front edge uses push pins into the grille flap some pics here https://gbodyparts.com/product_info.php?products_id=241&osCsid=2c05b622c60c98103f980789c7ce089e
Nov 20, 2018 #3 8 87we410877 Well-Known Member Joined Apr 5, 2005 Messages 2,634 pacecarta said: if they are new they should have come with the push pins sides use push pins and then get zip tied to bumper strut bottom flap bolts to underside of rad support using short 10mm head coarse bolts with an integral washer , front edge uses push pins into the grille flap some pics here https://gbodyparts.com/product_info.php?products_id=241&osCsid=2c05b622c60c98103f980789c7ce089e Click to expand... And that folks is a damn good response!!! Thank you so much!
