How do you remove the 84/84 Coil Pack?
BRAD_PADGETT
I cannot get the stock coil pack off the bracket in order to upgrade to the 87 type. Any ideas? Thanks- Brad
If your talking about just the coil.
It has 6 bolts, 3 on each side. Think they are #10-hex/star bit.
Remove the bolts,should lift right off. Has a gasket so might take a gentle pull.
The coil will be plugged into the ignition module, underneath. You need to take note of how and color of the connections.
If your talking about the whole coil/ignition module.
It has 4 bolts underneath the bracket, either 11 or 12mm.
ALso need to undo the ignition harness,think it's 1/4 or 5mm.
