how do you wire a biondi linelock?
wiked87gn
Banned
I got the biondi linelock, and i need to know how to wire it, i'm not using thier push button or wiring kit, just using a straight off/on switch and a home made fuse kit, where do you get the power for it and what is involved in getting it wired to the switch.. thanks in advance for any responses..
wiked..
First, if your NHRA inspectors at your local track are paying attention you won't pass tech inspection with that kind of switch. The switch has to be momentary (i.e., shut itself off). Last time to the track I saw a 10 second Camaro launch with his line lock on. Not pretty.
That being said, I don't have a momentary switch either. Haven't failed inspection yet.
I brought one wire to a ground under the hood and fed the other wire to the switch plate in my console. Found a constant hot (from the radio wiring harness) and hooked it up to the switch. Real easy.
Good luck,
Jim
