How far will 95lb injectors get me?
turboclam
My combo is below and will probably be runnin a 71HPQ, if I can find a good deal.
I have run my duty cycle up around 50 something percent with 160's .... you have more everything than me....
Not very far with that combo if its turned up to over 20psi. Dont run a HPQ either. Go to a 4 bolt and run the HPS minimum.
I went 127 mph with a 95% dc. Changed a bunch of stuff including injectors to 160's. I noticed I had a weak pump. Probably could have gone further with the 95's. The 71 will definitely max those out fast.
I was looking at the 4 bolt 71 HPQ, what's the difference in the HPS?
The hpq is the smaller version of the hps. The only ones that run that are guys running a 3 bolt ex housing. The hps won't fit in those. It depends on your hp goal anyway. The backpressure will limit the compressor from making as much power as it can if you fun it hard
