ok guys these are my mods
I am looking for 11s and maybe if it was possible 10s at the most
here is my question what is the fastest you can go with a duttweiler neck (how far will this carry me anyway?) , or what else would be limiting me to reaching my goal of the above
these are my mods and I am adding a TE-44 and injectors and a custom chip to this combo. besides slicks is there anything else I need to upgrade at all?
I do not want to go into the engine i.e. cam, crank, pistons. The most I would do is change the valve springs, I do not want to open the engine though.
here is the list
Gauges boost, temp, oil, tach, knock, air fuel, fuel pressure
RJC Powerplate
92Thrasher chip
THDP 3" with cutout and dump
Duttweiler Neck
Engine Tie Down
ash tray Switch Plate torque converter, fan relay, fuel pump
Pinion Snubber
Volt Booster
Big Mouth Intake
B& M Tranny Cooler
160* Thermostat
Racetronix plug and play with fuel pump
Driveshaft Loop
Adjustable Fuel Pressure Regulator
Scan Master
2 pod Console Pillar
Hooker Exhaust or the dual atr exhaust
HRPartsNstuff lower and upper control arms
Upgraded Crossover Pipes
Aluminum Pulley
CAS Aluminum Radiator
Jay Jackson Throttle body and Plenum port and polish upgrade
Ramchargers Boost Controller
GTA Black Honeycomb wheels
recalidbrated 145MPH Speedo
Shocks <--------------------------------what kind should I get?
Springs <---------------------what kind?
3 Pod A-Pillar Lotek
Rear Seat Brace Kit
Shift Kit
SMC alky kit
thank you very much guys
I really appreciate it
Carl
here is the list
RJC Powerplate
92Thrasher chip
Duttweiler Neck
Engine Tie Down
Pinion Snubber
Volt Booster
Big Mouth Intake
B& M Tranny Cooler
160* Thermostat
Driveshaft Loop
Scan Master
Aluminum Pulley
Rear Seat Brace Kit
Shift Kit
SMC alky kit
Carl
