How many Rpm's with TA rocker shaft and stock rockers?
IMO its not only the rpm's but the better cam lobe ramp angles and the higher spring psi as well. If its a FT cam with a 206 and 979's rock on. Any build thats getting up there in rpm and spring psi the RR time. Can it be done with the stock rockers and some grinds...sure lots of folks doing it. Too many combos to say exactly when you need it.
Way I look at the roller rockers are going to free up some friction, run cooler and be more stabile.
