John Larkin
Sublime Master of Turbology
- May 25, 2001
I need more stopping/holding power now that I have switched to vacuum brakes (please hold the "I told ya so's" for some other thread). Testing my line lock Sunday night, I had to set it with the brake pedal almost to the floor. This was after trying it with a decent push which the car just drove right through. I have the rear shoes set so that the drums just slip on. I haven't knocked the inserts out of the backing plates to adjust them with the drums on, which I think is the next step. Regardless, how much spin should I get out of a rear wheel with the tire off the ground, spinning it by hand after adjusting the brakes? I realize the rear end is going to dissallow most of the spin but how tight should they be realistically? Can I put a torque wrench on a lug nut, and spin the wheel with the wrench to find a "torque" like maybe 5 lb/ft? Just a reference would be really helpful; the wrench was the only thing I could think of that might be able to be duplicated. If anyone likes the way their car holds power and has time to check their brake setting with a torque wrench in this manner, I'd certainly be appreciative.
