How much is a new front pump?
Darkside
I recently rebuilt a 200R4 from a caprice and it shifts into reverse slow. I suspect the front pump has high miles and is no good. How much is a matched front pump body run? Anyone? Should I order from dealer? What part numbers would they be? TIA
Michael
if the pump was bad youd have other problems.use the money for the new pump to buy a pressure gage and lets fix it.post pressures.
We are now ................................
Installing our revolutionary Trademarked 4340 chrome moly rotors and slides in all of our transmissions. The only way they are sold is in a complete pump assembly or in a transmission purchased through us. They are THE ULTIMATE in pump components!
Tolerences are to the thousand/ thousand, not even the hundreth/hundreth. EVERY single set is IDENTICAL.
The down side?
Price. Not going to bull$hit you. They are VERY costly to make. However, this revolutionary part has solved many a pump failure in the 4L60E , which is what we originally designed it for.
If you are interested in persuing this direction, email or call shop.
PTS XTREME
Bruce
