how much is it worth?
tzque
Before I bought my GN I owned a Hurst oldsmobile . The T tops rotted so I decided to get rid of the car . It has a 406 with TPi and the same Trans and rear as the Gran National . How much are the trans and rear worth ? I want to keep the motor , The trans was done by Art car but it has sat for more than 5 years .
I don't know allot about olds, but if the trans and the rear are the same as a GN, then they should be worth about $500 each.
Good Luch.
The trans is calibrated different from a GN. The trans is an "OZ" code. It's calibrated for 3.73 gears and has different shift points than the "BRF" GN trans.
