How Much Stall Speed
van460
TH350 TRANS ,SENDING MY STALL IN FROM OTHER CAR. WHAT DO YOU GUYS RECOMEND FOR GOOD STALL SPEED, OR SHOULD I ASK CONVERTOR GUYS? BOLT HOLES DONT LOOK LIKE THEY LINE UP IS THERE SOMTHING I NEED TO KNOW? 200R4 V'S TH350.
We would need to know all about your engine, intended use, and much more. If you want, fill out a spec sheet on our web page and submit it with ALL the info you can, or call the shop. Then we can better discuss what you are relly neediing in a converter or a stall speed. thanks, Mark
