B BOSS 6 New Member Joined Mar 1, 2007 Feb 27, 2008 #1 How much will the RJC mega cooler help with a 450hp engine.
boostingbuick Going to be buried in this. Joined Aug 25, 2002 Feb 27, 2008 #2 What do you have now? Which turbo are you running and what power levels do you think you will get to in the future?
B BOSS 6 New Member Joined Mar 1, 2007 Feb 27, 2008 #3 I have a new pt-6152 218/212 roller cam trans built by Brian Hofer 3200 stall from PTC ported heads
J John Wilde I'm getting too old for this $#!% Staff member Joined May 27, 2001 Feb 27, 2008 #4 how do you like the 61-52 with that converter?
B BOSS 6 New Member Joined Mar 1, 2007 Feb 27, 2008 #5 it matches well with it have not try it with the new set-up but with the pretty much stock engine set-up it worked well
B Blown&Injected Active Member Joined May 31, 2001 Feb 27, 2008 #6 Imho If I were in the market for a new one - that would be it. I am sure it is more then needed for what you are doing right now but I do not see it hurting and it will be waiting for more
