I have a TA 62 with 50 lb inj and stock unported heads (only valve spring upgrade) 212/212 cam, 20 row IC, 340 fuel pump, adj reg. I would like to turn it up around 25-26 lb of boost. Want to see some good e.t's. I will use C16 fuel at track. What is the realistic timing I should have in a race chip.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
