John Larkin
Sublime Master of Turbology
- May 25, 2001
I am planning to buy some used wheels but do not have an opportunity to put them on a balancing machine first to check the runout. I have bought a bent rim before and want to avoid it if possible. I am trying to come up with a way to make a DIY tester. I was thinking of something that could bolt to the backside of the wheel center with a swinging arm on it to check the outer rim to make sure it is parallel to the center. I don't have a car to take with me with the same bolt pattern so I can't bolt them to my car either. Surely there is something. It would have to be a perfectly perpendicular arrangement. I do have a good wheel I can set it up on first.
