BMF_Racing
ONE B.M.F.
- Apr 26, 2006
STUFF/TOOLS NEEDED:
- Casper plug-n-play MAFT Pro harness
- MAFT Pro standard harness
- soldering iron/pencil with flux filled solder
- small heat shrink tubing
- lighter or heat-gun
- wire stripper/cutters
The Factory Harness for MAFT Pro:
The Casper p-n-p Harness for MAFT Pro
match up the wires from the connectors back.
the cut off ends you dont use from the Casper p-n-p Harness
cut the above ends off the Casper p-n-p Harness and solder the wires one at a time to the MAFT Pro harness, but dont forget to put the shrink tubbing on first
all soldered together
heat the shrink tube up with a lighter or heat gun centered over the soldered area
finished product is now plenty long:
close-up
so what does everyone think ??
close-up
