How to ohm out coil pack?
klmnla
Watson LA
What terminals are used to ohm out and test the coil, and what are good and bad readings? If these 10.4 mm Taylors and new R43TS plugs dont stop my issue, I m sure the coil will be the next in line.
Try ohming the coilpack out front to back, should be between 11-13k ohms.
