buickstage II
- Jan 24, 2005
Hi guys,
i have a set of stage II heads (25500031 stamped with "R")
machined for jessels
they have threaded ports at one end of the heads which go into the rocker bridge stud journals!!! - are these used for anything?
im wanting to run hydraulic lifters, the blocks an off center and cross holes are allready there, so i can feed the rockers from the pushrods then?
what prep work do the rockers need?
they have through hole adjusters also.
another question is that the jessels don't have any threading for a stud third in from one end???
need help
thanks Simon
need help
thanks Simon
