There are several variants.
The only ones I trust, and that's a personal desicion, are Baileys, available thru Ramchargers. If you know what stock looks like his add a few lil dodads, and he uses a white, kind of caulking to protect the modifications.
Some have been modified with just using larger switching transistors, and those you can't tell from stock, unless you really know what stock looks like, You might be able to detect the clear stock covering has been removed in them to R+R the stock drivers.
And the screws holding the printed circuit boards to the spacers have had the clear disturbed to be disassembled.
BTW, you want to take all four screws out on the RIBBON side spacers, and then the 2 screws on the opposite top side. Wiggle the spacer out, and then you can slide the top board back and out to open things up, and look inside. All the injector drivers bolt to the large heatsink.
HTH
