- Aug 1, 2003
theres only one gasket for the vac block .. you can get a gasket frompete hoffman or there should be one with the vac block like the billet from kirban
where ... every one wants the easy button ... i vary the location depending on the plenum (stock /pte /accufab - KB / hemco/ champ race ) and if it also needs other ports like IAT (for speed density ) or vac ports for map sensors ...pick a spot that will accept the fitting and not interfere with bolts that hold the coil pack bracket or plenum , you will need to drill and tap for the fitting you get which should be atleast a 1/4 npt fitting to 3/8 hose barb ..like this http://www.jegs.com/i/JEGS-Performance-Products/555/16032/10002/-1?parentProductId=763082
