Well, you have to look and see what dashboard # you data log with. Then go into "dashboard", then "edit dashboard". Go to the dashboard you use when you log and change one of the sensors to MAP (psi). You do this by hitting enter on one of them and going through the list of sensors until you find one you want and hit enter again (DOS software). Be sure and leave MAP (kpa) in teh dashboard or you won't be able to overlay your logs onto your tables. Hope that helps. Good luck
