hr parts or bmr rear sway bar ground clearance
asloan5
Corn Fed alcoholic
anyone please let me know clearance between bottom of your rear sway bar and the ground and what tire size you have as well. Please only respond if you have hr parts n stuff <- newer model or the bmr xtreme anti-roll bar and one last question how much space do you have between the bar and axle tube where they run parallel just in the inside of the bar mounts ? and is the bar straight below the rear axle tubes or is it clocked to the rear of the vehicle to gain ground clearance ?
I bought a bmr bar and have a stock size tire but my ground clearance is about 3 inches between the bottom of the bar and the ground ... looks to close for me
