87gn-newbee
- May 25, 2001
Allready have good oil PSI 60 cold 24 hot idle and wondering if a HV front cover will cause problems, oil leakage? Saw the TA Perf HV front cover with an adjuster on it at Bristol. Do all HV front covers come with an adjuster? If so I should be able to play with it right?
Which HV front covers are you running and any fit problems?
Second option is stock cover/gears with booster plate (maybe). Heard good things about the TA Perf cover but it cost a few $ more, is it worth it? What about Silver Seal or PTE's. Which to go with.
Dan
Dan
