HVAC vacuum leak
MistaScott
Abnormally Aspirated
Tested my vac lines with MityVac and I am leaking from the HVAC line that comes off the check valve near the coil pack. It goes down behind the AC unit and disappears into the fender. Any idea where that goes and how to get to it?
My heat still works fine and I can't hear any hiss nor are there any visible cracks in the line.:confused:
Ok, figured all that out. Has anyone ever had a leak in the HVAC system, if so where was it and how did you get at it?
