Hyd Roller Cam Install
87Gnastey
Just installing my hyd roller cam and was wondering if there were any tips for adjusting the thrust button.
What kind of end play numbers are exceptable?
If your doing it in-car.. a little play is all you need. .005
I could be wrong, but I dont think if you set it at .003 or .008 it will make any difference. You def dont want .000 or for it to be sloppy .010+
Dont glue the gasket down.. and triple check it. When you tighten down the front cover hard, it will reduce the number as the gasket compresses. Once everything is squared away, glue the gasket and install.
A lttle play is fine.. and all thats needed.
Thanks!
Those were the numbers I probably would have went with but it's always good to check.
Any suggestions on a good thrust button?
I've only used the one from Comp with the multiple shims.
I just made sure there was some movement in mine with a screw driver, as long as it had "some" play and not a lot of play I called it good...No measuring.
