Hello! I'm actually from the RealOldsPower forum, and recently had a problem with a Mondello/Engle hyd roller camshaft failure and was told to check out this site as there was a big problem for you GN, GNX, and TR guys just a while back.
I went exactly by the book with this motor, and spring pressures were exactly as recommended. 140 lbs max @ seated, and 340 lbs max @ open. Only 7K miles on this master rebuild with many mods, when I find that every single lobe had about a 1/16 inch groove wiped out of it (same width of lifter bearing) There was also a bronze cam spacer and thrust bolt button used on this, but cam still was not centered correctly, almost looks like it is centered for flat tappet lifters. I don't know if this forum supports posting pictures but I'll give it a shot. If not, there will be a link here instead. Check it out!!
Some have said that it looks like Mondello had sent me a cast iron core flat tappet cam which was supposed to be a 8620 billet steel hyd roller camshaft, that is what I'd paid for. Mondello is notorious for ripping people off, but I didn't learn this until after the purchase was made. "If I only had known then, what I know now". The way I am being told by many people is that, hydraulic roller lifters are not compatible with cast iron core camshafts, it will work for those with low spring pressures, but where is the line drawn at? Any and all input regarding this subject would be very much appreciated.
Thanks a million!!!
Robin L. Buddi
