Hyd Rollers in Stg11 Blocks.
9SECVSIX
Looking for maximum spring pressures for a hyd roller cam in a Stg11 block, Champion Al heads. Seems due to the better oiling system one should be able to run higher pressures than in a 109 block:confused:
9sec.
I run a comp 985 double spring, It gave a around 140-145lbs on the seat. I dont remember the installed height 1.750 maybe? I dont know exactly how much higher you can go witout collapsing the lifter. These springs took me to 6500rpm on the shifts, but normally I shifter earlier 6000-6200rpm.
Hi Brent, your mailbox is full............sent you a long message for not.
Will try again later.
Take care,
Mike.
