- May 28, 2001
Been working on this for several days.. No cure found.
Unit is on a 65 Impala w/ a type 1 pump/reservoir combo.
The boost is new, as is the pump, and lines.
Once filled, we turned the steering side to side at least 40 times, added fliud as needed. Found a leak, fixed it.
The HB return is tee'd at the gear return port w/ -6 line. The return then goes thru a filter to the can.
Once we decided to start the engine, the pump immediately became loud. Shut down, and added fluid. Same result. Jacked the car up, turned the wheels an other 20 turns. Same noise, but greatly diminished, if no steer input. Tried the brakes. As soon as the pedal is touched, the noise starts. Could hear it for a block.
Shut down, and checked fluid. Removing the cap resulted in a huge puddle. Oil looked like soapy water, as it was totally aerated. Let it sit, and the level returns to near full.
Some say that it's absolutely necessary to have a separate return port in the reservoir. Some say no.
No leaks, all new parts, wondering if the return plumbing is the issue
NE1 have such experience? If so, what was the "cure"???
TIA,
TIA,
