Are you talking about the PowerMaster pump/motor?
If so, just don't let it run more than 20 seconds at any given time.
If it doesn't begin pumping immediately, crack the pressure line loose at the cylinder (under the acc ball) and let the motor run for a moment and that should prime it.
Pump it down and then do it again to bleed air out of it before you use it for driving.
If you are talking about the Powersteering pump. No. Just start the motor and run the steering wheel back and forth a few times until it shuts up.
HTH.
