I need a little help with the Hydroboost system on my 83 T-type. The wife was driving the car last Friday and said the brake light came on then went out. I checked the car when I got home and found that when you press the pedal the brakes would engage and stop the car but you could push the peddle all the way to the floor. Is this typical of the hydroboost system? I check for leaks at all the wheels and around the master cylinder and found none. I went ahead and replaced the master cylinder just for saftey. Any input from the hydroboost masters would be welcome.
TIA
Greg
TIA
Greg
