bmackinnon
- Feb 24, 2005
The hydro setup is already so long that it interfere's (or VERY nearly so) with the PS reservoir.... so I don't believe there is room for a spacer. Of course, I guess you could modify/relocate the PS reservoir... Along with the OP's problem of brakes not releasing.... I have 'READ/HEARD' that you can have that problem when you 'T' the two return lines to the reservoir. I think in some cases, it results in too much backpressure in the return line from the hydro, causing brake non-release/dragging issues. It's preferable to have a seperate return for each piece (PS rack/h-boost) dumping into the reservoir.... which requires a different reservoir, or modification of the stock one.... A few of the MANY reasons I went vacuum 5 years ago... :redface:
