I've done a lot of reading on the subject. I installed a hydroboost system on the car and bled the m/c on the car by hooking lines from the ports up into the reservoir and pumped it as instructed till no air. Then hooked up the lines and bled the lines starting at rear ps... Pedal got firm. Took the car for a drive and the brakes felt fantastic! Didn't try to load them up hard as was concentrating on braking in new engine. Then a buddy noticed my brake lights were staying on? So I thought perhaps a switch problem. But with car not running they go off and on just fine. However with engine running you can actually push the pedal right down to the floor and it doesn't return all the way to the top. So I held the pedal to the floor an put it in gear and gave it some throttle and they are holding way better then they did with the pm system. Seems like most issues end in bleeding. Any ideas what would cause the pedal not to come to the top?
