I believe a warmer is needed
EclipseTurbo
After much testing, I believe a propane warmer is very much needed to get consistent results.
Here in CA, mid Feb, still getting about only 50F in the morning and night. This translate to roughtly 80-90 PSI propane pressure at the tank.
So it's no big deal if you only want to run 80 PSI propane pressure, right? Not really. What happens is after a couple of runs, the propane tank pressure will drop further (about 10 PSI) Now the pressure at the inlet is pretty much 80 PSI, which doesn't give much headroom for flow (read on)
What happens is when the solenoid opens, I think the pressure drops some more. At 80 PSI inlet, it will drop below 80 PSI, (still need a backseat rider to confirm, but I'm pretty sure that's what happens) now if you have 110 PSI or more (afternoon temperature for example) The pressure will be much more consistent, because the inlet pressure is still high enough to be supplying the outlet pressure.
I've had no knock when the inlet pressure is high. Let's say I tuned the car nicely in the afternoon, it will knock when cold because the pressure just isn't there, or consistently there.
So what is the solution? I believe it is the need of consistent inlet pressure. I believe a warmer that keeps the bottle roughly around 140+ PSI will be fantastic.. it does not need to be exact as the regulator will do the trick.
I talked to speedshop.org and he said he had one that will control via pressure feedback (fancy), but it's not fully tested, that is overkill because we use a regulator already. I think a simple, intermittent timed warmer will work just fine.
I think Ive been saying this for a while.
In about another month, though, all this will be irrelevant.
We're working on a new warmer. I really recommend not using the pressure actuated warmers.
Good to know, Jay.
If you have a product, I'll definitely consider buying it anyway.
It is all just extra safety for the engine.
It has been getting warmer and I have been doing some tuning.
I found that after repeated runs the propane tank drops below ambient (like it came out of the fridge!) and my presure drops quite alot. If I let it recover to room temperature (slow) pressure goes back to normal.
I really think a warmer is needed if you repeatedly go WOT, even in summer. The propane just runs on it's own temperature and the ambient temperature really does not contribute much.
