Took a LOT in AE vs TPS delta. More than I had tried. It got worse before it got better. I guess it started out so lean it was just a bahhwaaaaa, then bawplplaaaaa then I added some more as a WTF, why not try it thing, and now it acts like a perfectly tuned carb
My VE table in this region is under 1% correction so those with the VE table set will probably simple need to mod the TPS delta table, Those with a less than set VE table, should get that straight first.
Heres my AE vs TPS delta graph for those with the problem to try:
http://www.turbojim.com:231/jim/jimaevstpsdelta.jpg
This is a stock long block w/Delphi 65's
Injectors with different characteristics might need more/less
Ohhh I'm happy now
Runs as good as the stock ECM did now.
Ohhh I'm happy now
