I need a crossmember for dual exhaust
If you have the Regal's single-exhaust crossmember, it can be easily modded to work with dual pipes. You'd need a torch or plasma cutter to cut a "semi-circle" out of the bottom side of the crossmember to clear the driver's side exhaust pipe. You can leave it at that and it will work great or you can invert the cut-out piece and weld it back onto the crossover to create a tunnel for the pipe.
Been There Done That - HTH - Jimmy
thanks i have no clue where the stock one is i bought a jegs dual one last year and its the biggest pos i ever seen to short dual humps dont line up with headers its horrible
A single exhaust set up properly will give you better scavenging and more torque than a dual. If you do it right with a free flowing muffler it will flow as well as a dual as well as get you off the line faster.;)
