I need a pic of the correct door mouldings
jetmech
I purchased a roll of moulding and it doesn't seem right. any one have pics of the correct mouldings for a gn. thanks
Does anyone have the measurments of the mouldings in inches from the fender, door and quarter panel.
Got a piece of the original factory molding here along with the replacement molding that Kirban sells. The only significant difference is that the Kirban molding has kind of a pebbled texture to it where the original factory stuff had a kind of random indent type of finish. They are reasonably close in all other respects.
The door molding stops 1/2" from the front of the door edge and 1/4" from the rear edge of the door. It also has those same 1/2" spacings from the rear edge of the front fender and the 1/4" spacing from the front edge of the rear quarter. Distance from the body crease is 8 1/2" down to the molding on the doors, 8 1/8" on the rear quarter and 7 3/4" on the fender. Other than that, just line them up so they look straight.
Thanks, but i need the total length of body moulding to do one side of a car. I just dont think i have enough because the second piece of moulding i have is only 13.5 inches and i think it will take a little more to do the fender and quarter.
The door takes right about 57", the front fender 7" and the quarter panel takes just over 15" of molding - looks like your 13" piece is only good for a front fender. It takes almost 14' to do the whole car.
