- Aug 1, 2003
swap the wires A+C ...hotair tps cant swap with 87 tps they work differently
also note the high tps reading with throttle closed put the ecm into clear flood mode ..so explains the no injector operation as that is cut off while in clear flood mode
if you had connected a scantool like scanmaster youd have seen the tps error earlier
