New Member Needs Advice/Guidance please
86ATR
Team TB,
I recently purchased a 1986 GN that has not run in many moons. The previous owner replaced tank/pump assembly. It currently has a TON of ATR pats like the air filter(black cylinder) looking thing, a 7th injector, an ATR wastegate and goodness knows what else. I plan on getting it running properly but need some initial guidance with an issue.
The vehicle has a very , very long crank before it starts. I'm talking 30 seconds or so. When cranking, it will also seem to pop through the intake. After about 20-30 seconds of cranking, it will start and seems to idle well. I have not let it run for more than a minute or so at a time. Once it has started, it will restart normally. It cranks like it should and fires up with no extended crank. I have an old snap on brick scanner and pull no codes.
Can anyone provide some guided diagnostics to start? I have not checked fuel pressure or leakdown due to the pump and tank being new. Assuming that pump is ok. I will be sure to check over the weekend. What is confusing is the popping while cranking until it starts.
Where are you located?
When you turn the key to the on position, the fuel pump should run for a few seconds. Sometimes it is difficult to hear over the door chime. There are two relays on the passenger side inner fender. One for the A/C & one for the fuel pump. Check the pump relay.
I can't help with the "popping" you describe.
These cars require a substantial investment in either dollars, homework, or both, to maintain them.
Here are a couple more resources:
I am in Atlanta. I am working hard to learn as much as I can. GREATLY appreciate everyone's knowledge and input
Team,
This car has a ton of ATR items installed. It has not run in years. New tank, pump. It has an external ATR wastegate, ATR cold air intake, 7th injector to name a few. For the life of me, I can not find where the boost control would be. Is anyone still running any ATR stuff? Anyone have installation/operation guides for this stuff? The old owner has passed away. I have no way of finding out what was done. This was done many moons ago.
Long shot, but mine popped when I was driving it on the test run at the seller’s establishment. It only showed that it had 2 gallons of gas in it. Added more gas and the popping went away.
