marleyskater420
still needs to learn
- Aug 14, 2004
We both argue pointless crap about cars all the time..
Our argument at hand, is if turbos are load based, or rpm based, and if gearing dictates a load on the engine.
I say turbos are load based, he says rpm based.
I say different gearing will dictate a different load on the engine.
Like pulley ratios in a sense.
He says " there is no change in load on the engine when you get gears. the load is the weight and innertia of the car, and the car performs differently when you change your differential gears not because of load, but because you are going the same speed but with higher revs"
This is stupid, but I win 5$ if Im right, and I show him that Buick>Ford.
