slamming 6
Drag Master
- Jul 21, 2003
I have two 153 blocks one block has cross bolted mains front&rear the other has all of them cross bolted don't know why any info would be appreciated. thanks AL.
SignUp Now!slamming 6 said:I have two 153 blocks one block has cross bolted mains front&rear the other has all of them cross bolted don't know why any info would be appreciated. thanks AL.
odell4o8 said:i have a 153 4x block that has cross bolts in front only. oc,
neal, i got it from ron,750H.P.V6 said:OC,
I know Ron Tarabori had a couple of those he sent me pics.of. It makes me wonder if they ever made 2 blocks the same. I'm sure there are more variations I'm not aware of.
Neal
750H.P.V6 said:Your 153 block with the 6 bolt mains was one of the latest castings.
HighPSI said:Neal,
Are you sure about this? I was told that it was one of the earlier 153's and they later changed to the 1&4 design. Not disagreeing, just curious
HighPSI said:Neal,
oldtimer said:Cal,
I sent you a copy of the UNI-BORE sonic test sheet along with my virgin stage 2 block. It had the block build date on it. As I recall, it was built in the late 90's
and had the 1&4 design.
I tried to find my original copy, but just can't locate it right now. I'll continue to look and when I find it, I'll post the actual build date.
If you still have the sonic test sheet for my block in your files, it might answer this question of when the 1&4 or all 6 were built. I'm not sure, but I think my block was built on the last re-run of the Stage 2 block.
George
HighPSI said:Neal,
